ok now that we got that out of the way
as i suspected, those serial numbers will not bring up anything in my database so MFCA does not have a specific manual and those would be covered under the MCFE manuals.
So if anyone in europe has any info on these trucks maybe they can help you quicker.
I will look and see if i can find anything related to this model truck but it will take me time to go through the material to see if i can find anything.
Now i ask you if there is any specific problem you are having that we might be able to help you with? codes? symptoms?
Sending a complete manual is not my first choice as it is way to large to send through any email service i use and copyright laws prevent me from doing so anyway. So what problems are you having with this lift?
Hello, Swoop
this serial number it`s not for a certain truck but i`m sure it`s the same model.
Cat DP30, S.N is: 7BN11006 or 7BN1108 ''another truck''.
hope it`s help.. thanks for your time
Folk
no problem for_y
now to make sure you understand i myself may or may not have what you are looking for. The only information i can search for by serial number is for North American fork trucks (ie: MCFA)
Your truck is classified under the Europe or South American divisions which would be MCFE i'm pretty sure.
I'm just getting you to post a serial number so me or anyone else can help you better.
I will look through my material and see if i have anything because sometimes cat manuals even the american ones do contain european information, it just takes more time looking through it is all.
Thanks a lot Swoop
I will search again and came back to you
trust me its there
you may have to scrape some paint off but it is stamped into the frame at one of those places.
the reason for serial number is to give accurate information
without that whatever is sent to you may or may not be right
nobody wants to waste their time or yours sending information that would be wrong.
Dear, swoop
I looked hard for any data... and got nothing, because it`s repainted
please, send me what you have and i let you know if it`s right ?!
thanks a lot
Folk
going to need a serial number first for anyone to get you the right manuals.
Check on the right side of the motor compartment on the frame around where the hood rests and see if one is stamped in the frame there. If not there then it may be stamped on the front of the truck, on the fender or front cowl.
Cats usually serial number configuration is a letter, some numbers, another letter followed by more numbers. Generally a 9 digit or more designation.
