Cat 2EC20
Error code 30. Smoking transistor behind contactors. Please advise.
  • Posted 6 Jul 2016 20:56
  • By AskJason
  • joined 9 Oct'15 - 7 messages
  • Missouri, United States
a serial number of truck would be most helpful
but assuming this truck has microcommand control the error code 30 indicates a shorted T1P or T2P transistor.
possible causes are:
- open wiring
- failed pump driver board
- failed logics
- open circuit in pump motor PA1
- PS2 cables
- welded pump contactor tips
check all connections related to the pump circuit
check the pump contactor tips, make sure they are not welded shut
check the pump motor & cables for shorts
if all of the above check ok then there is a possibility the pump driver board is bad.
in any case the smoking transistor should be replaced and the cause of the problem found that caused the transistor to release it's magic smoke :o)
  • Posted 11 Jul 2016 02:22
Justin Byma Justin Byma
VP global product manager and strategy, Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Combilift Ltd
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
