Can a Clark standup be programmed to not move over 1 MPH with forks fully extended?
Is there any safety features that can a programmed into standup lifts that would slow the unit down when forks are extended up? We have had two accidents, 1 flip over and 1 overhead camera damaged, other than driver training is this a safety feature any supplier provides?
  • Posted 5 Jan 2021 07:46
  • By FanMan
  • joined 10 Nov'18 - 4 messages
Rick Lemaster
chances are it can be programmed to slow down when raised so speed is limited but it would have to be a custom setting made by a tech.
It's not something you can do other than to use the operator 'preset' modes which are most likely not slowed down that much.
Most newer lifts do have access through the dash but what you can adjust is limited. To get what you want it would have to be done with a handset or laptop depending on what system is in the truck.
  • Posted 8 Jan 2021 00:09
  • Modified 8 Jan 2021 00:10 by poster
We have Clark NPX reach lifts, there is a limit switch on the mast to lower the speed but it is pretty high up on the mast. So far we have not found a setting to change speeds at lower heights. Not my favorite lifts!! cheap wiring
  • Posted 8 Jan 2021 00:01
  • By GBry
  • joined 7 Jan'21 - 1 message
  • Tennessee, United States
No problem. When clark tech comes out to adjust settings, see what other adjustments are available. lift accel, decel, speed, etc. It can get your lifts to perform better for your particular use
  • Posted 6 Jan 2021 07:34
  • By Triggs
These are lees that a year old. I got a hold of Clark rep and there is a setting to limit speed with forks raised. I wish I knew that when we crashed and destroyed a brand new lift as it toppled over with operator driving it with forks 3/4 raised. Thanks for the reply tho.
  • Posted 6 Jan 2021 07:12
  • By FanMan
Rick Lemaster
How old are these clark reach trucks? Im not familiar with clark reaches, but modern canbus trucks such as crown and raymond have just about every possible setting and adjustment available thru the display module
  • Posted 6 Jan 2021 06:56
  • By Triggs
Toyota 4FD240
Elwell-Parker ESI500-36
Lift Tek Elecar
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Lift Tek Elecar
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
