Cab Heaters
Having "issues" with our cab heaters.
Our new in spring of 2014 BT's RRE200CC have a new style heater, ie: variable speed fan and variable output heat capability, as opposed to the old 3 speed version.
Fuse F94 ( located in the heater assembly itself) doesn't really blow... one leg of the fuse overheats SO BAD it melts the fuse. Maybe it's a poorly made little fuse holder, and the "jaws" that grip the blade, don't grip aggressively enough, so... poor connection = heat = melted fuse ??
What I'm trying to say is the fuse isn't really blown , in the normal fashion it's melted ??
This fuse supplies current to one of the electric toaster grids that supply the heat, I believe.
Anybody got any thoughts on this, seen it before ??
  • Posted 17 Jan 2015 02:08
  • By UncleSi
  • joined 12 Feb'13 - 135 messages
  • Manitoba, Canada
Thanks FKABT and all.
I'm going to do just that.
Took some photos of the problem and will see what they come back with.
  • Posted 17 Jan 2015 07:38
  • By UncleSi
  • Manitoba, Canada
Best thing to do is contact your BT Toyota dealer & complain, the heaters shouldn't all be failing like this.
Ask them to contact BT tech services in Sweden & lodge a product quality complaint.
  • Posted 17 Jan 2015 04:19
  • By Forkingabout
  • england, United Kingdom
2802 hrs. on truck 1000 hrs. on heater module ( 1st one replaced on warranty cause someome drove a screw into one of the little modules inside, at factory )
All 3 of our trucks are doing this.
All 3 trucks off warranty because of usage/hours.
Air filter is clean/minty !
Another unit the fan quit working... I don't even know how to test fan ie: PWM controlled DC fan motor and PWM Module ??
They went away from the 3 speed simple units to these variable speed nightmares.
  • Posted 17 Jan 2015 03:27
  • By UncleSi
  • Manitoba, Canada
How many hours on the truck?
Has the air filter for the cabin heater even been replaced?
Is the truck still under warranty as it sounds like its less then a year old.
  • Posted 17 Jan 2015 02:47
  • By Forkingabout
Thanks Stam
That sounds scary !!
I'll get hold of Johnston and check that out !
Appreciate it !!
  • Posted 17 Jan 2015 02:23
  • By UncleSi
  • Manitoba, Canada
give Johnston a call and have tech dept. check for service bulletins on this truck. if my memory serves me right there is a bulletin out for bt heaters, something about melting/fire hazard...
  • Posted 17 Jan 2015 02:18
  • By stam
In ancient Greece, dolphins were considered sacred animals, closely associated with the gods, especially Poseidon and Apollo. Because of their religious and cultural significance, killing a dolphin was treated as a serious crime and could be punishable by death.
