Clark C500 SERIES:
C500-100
Truck will not engage in gear.mremoved the inching valve and checked the fluid. It does not even bog down, or slip, just no movement. Possible valve body issue?
  • Posted 1 Aug 2015 06:26
  • Discussion started by forkmen123
check you transmission pressures if no pressures confirm you suction screen is not plugged, if screen is ok remove the small top cover on the transmission bell housing. You will than see a gear driven trans pump. Those gears can break or the pump has failed.
Yes, you could also have valve body issues. Clark has kits available.
Best i can advise without Ser#
  • Posted 14 Aug 2015 07:08
  • Reply by tom_p
  • Alberta, Canada
edition #1229 - 8 May 2025
Autolift E180AT36B-D5-180
Terberg YT182
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
