Hi everyone,
I heard that there is a regulation\obligation that demands burst valve installation on lifting hydraulic cylinders.
My question is, if this requirement apply in forklift hydraulic cylinders?
If positive please note known source\standard.
Thank you all
FYI. In the days before ( early 1980's & prior) multiple lift cylinder mast designs the max rate of decent in the event of a lift line rupture was controlled by a thing called a flow regulator valve located a the base of the lifting cylinder.
Thank you Brewski,
Do you know if there is a directive in the above noted std. at the subject I have asked?
In the U.S.A., I believe, the standard used is in the ANSI standards for lift trucks. Not sure of the number. Found it. ANSI-B56.1
Yes, also called velocity fuse
Also known as velocity fuse?
