Bt Industries VR:
BT VR narrow aisle c31
Hello,
I have problem with error code 31, that should mean defect sensor bearing or cable in fork sideshift. Sensor bearing signal is ok, syncro-movement from one side to another works, but not the sideshift/reach-movement. It moves 15 cm, then the error get trigged. It wont get trigged if I don't pull the lever all way, but then it will be really slow. Has anyone any ideas what can cause the error in this case?
  • Posted 10 Jan 2015 01:08
  • Discussion started by lars_s
  • Finland, Finland
HI
I have a VRE150, Man down narrow aisl.
The hydraulics are working finr. The carraige wont move on the geares and the swing wont happen. We are detecting a code C81.
Can you please help with the service manual.
I have 2 machines, both with the same problem.
please help.
  • Posted 13 May 2016 20:57
  • Reply by pankaj_s
  • Maharashtra, India
marketing @ asiangrpindia. com
The problem was caused by the proportionalvalve Y25. The valve didn't open enough and the pulses from encoderbearing became too slow, and logics gives alarm 31. The machine works fine with a new valve.
  • Posted 23 Jan 2015 18:54
  • Reply by lars_s
  • Finland, Finland
I have connected my test-istruments to the logic card, so it can not be cable problem. I have checked sensorbearing with osciloscope, fork-rotator potentiometer, and the end-stop sensors. I have also changed lever between sideshift/reach and rotate. The sensor bearing change was the first thing I did, before I started look for other. Synkro-movement (automatic change from one side to the other) works perfect, until you want to reach for a pallet. A bad sensor or harness would stop the synkro also, wouldn't it?
  • Posted 10 Jan 2015 02:19
  • Reply by lars_s
  • Finland, Finland
Wiring harness checked / tested ok?
Check the proximity sensor that senses each traverse end stop is working at each end of the traverse.
Sounds like it will be new sensor bearing & horn time.
  • Posted 10 Jan 2015 01:19
  • Reply by Forkingabout
  • england, United Kingdom
JLG G12-55A
UN Forklift FB25N1LZ1
