BT RRE 160 From 2010
Hello
I just got a BT RRE from 2010 in good technical conditions, but i have few questions. I cant find online a user/technical manual, because i have few questions as:
1. how to open the cabin?
2. how do i configure a user profile (if its possible to my model)
3. how do i made the maintenance of the battery
4. how to i set a pin code
5. my truck is equipped with weight management and handling system (motorola vc5090),so here i have 2 more questions: how do i preset a height value, and second, how do i connect the vc5090 to my router, its keep trying to connect on the warehouse network where was purchased.
THX in advance
  • Posted 28 Jun 2019 05:49
  • Discussion started by cristian_b
  • Romania
Do you have a BT CAN service key?
If you do then please do NOT connect it to the truck as it unlocks all the hidden service / calibration features & on a RRE this can be dangerous unless you know what each individual service function will do before you activate it!
Consult the service manual / ask someone that knows RRE's first.
What software package is it running? Truck switch off, press the I button on the CID & it should display the software package 260038 - ****
What is the **** part? The calibration procedure changed at version -010. Later versions introduced a new service function to test the support arm brakes on to the truck.
Using an out of date service manual for calibration with a RRE with later software will mess the calibration up.
You mentioned opening the cabin? Is this a tilting cab RRE?
You need a BT CAN service key to open the tilting cab in service mode.
Does BT / Toyota know you have this RRE machine / have you checked for any outstanding safety recalls for it with them?
  • Posted 28 Jun 2019 17:10
  • Reply by Forkingabout
  • england, United Kingdom
Wentzville, MO, United States
Ottumwa, IA, United States
Harrisburg, SD, United States
edition #1235 - 19 June 2025
Terberg YT222
Unicarriers FHGE35T5S
Noblelift
