bt rr m14/15
problem with side shift getting 48 volts at one side which ever way the lever is positioned left or right,and no voltage over 27 at the other solenoid,,,,,,,
switch is working correctly 7 volts at either side ,,,
any help
  • Posted 4 Sep 2009 01:14
  • Discussion started by basher
  • Alabama, United States
You should be able to see the LED's operating on the A5 card (under the arm rest). Is there a fault code coming up (probably 25). The harness that runs next to the twin hose is a common problem. Does the hose look as if it is under pressure when you actuate the lever? If yes, its is probably a break in the cable. to check what wire, look at the fault codes.
  • Posted 4 Sep 2009 20:57
  • Reply by Leon_W
  • Tyne & Wear, United Kingdom
Linda Häkkilä Linda Häkkilä
