BT forklift RR E7 / 2007 appear error code when lifting or moving
Dear sir,
I have some problem with my truck after replacing the new sensor bearing. When I moving the truck with high speed, the dash display appear error code E104 and truck stop. When I operate the lifting function, the dash display appear error code E107.
Anyone can help me how to solve this problem.
Thanks & Regards
  • Posted 7 Jul 2014 11:59
  • Discussion started by David_nguyen
  • Binh Duong, Vietnam
trung_klc@machinery.com.vn
Have you removed the long plastic arm rest panel recently?
The service switches at the front under the dash on the bracket are easily caught when refitting this panel, one of these switches is for emergency brake release & will throw error code E104.
Its a common issue on the older Reflex machines.
  • Posted 16 Sep 2019 02:55
  • Reply by Forkingabout
  • england, United Kingdom
Forkingabout@aol.com
Error E104 electromagnetic break open or loose connection
Truck working in slow condition rev and fvd
  • Posted 13 Sep 2019 17:11
  • Reply by rahul_c
  • uttar pradesh, India
Rahul chaudhary
Dear sirs,
I have just solved this problem. I have double checked and found that the battery voltage is very low although the battery indicator show full (100%). So the truck can not work correctly.
Anyway I also thank you so much for your advice.
Regards
  • Posted 14 Jul 2014 16:49
  • Reply by David_nguyen
Replace the 300 amp fuse on the A2 card.
Check the 3 pump motor cables are secure.
You didn't happen to untwist the 3 cables when working on the motor?
  • Posted 10 Jul 2014 16:19
Dear Mr Forkingabout,
I have checked the battery cable to K10 contactor and A2 card. It is OK.
I have checked the blade fuses inside the motor compartment and they still good.
I replaced the genuine BT part but I did not replace the horn before repalcing the sensor bearing.
I also try to swapping the A1 controller with A2 controller but the problem is the same.
Sometime the truck appear error code E228 or 231 when lift the mast with high speed.
I know that I do wrong something. So please help me in this case with more detail.
Thanks & Regards
  • Posted 10 Jul 2014 12:32
  • Modified 10 Jul 2014 12:33 by poster
First thing would be check the battery condition then check the battery + cable up to the K10 contactor & - cable up to the A2 card.
To get E104 & E107 errors when driving / lifting points to a lack of correct voltage issue.
Have you checked the blade fuses inside the motor compartment?
Did you remove the armrest panel during the repair?
Genuine BT part or SKF speed sensor bearing fitted?
Horn replaced before the bearing?
  • Posted 10 Jul 2014 07:02
  • Modified 10 Jul 2014 07:04 by poster
Have you checked your motor for current leakage?
  • Posted 10 Jul 2014 01:57
  • Reply by tasos_t
  • ATTICA, Greece
Dear Mr Gopal,
I have checked the wiring as your instruction but it still Ok. These problem only happen after I change new sensor bearing. Please study and advise me for next step.
Regards
  • Posted 9 Jul 2014 13:31
Hi,
For the error code 104, check the brake coil wiring, it may be short some where or brake coil faulty..
For 107 Error.. there may be the cable no 22 somewhere in the truck is in contact with truck body.. or hyd oil/ dust may shorten to the cable no 40.
Good luck..
  • Posted 7 Jul 2014 16:06
  • Reply by gopal_s
  • karnataka, India
GOP
Ottumwa, IA, United States
Wentzville, MO, United States
Harrisburg, SD, United States
