brakes not working right??
We have an old hyster, model #:S30XL. the brakes went out so we tore in to it. We replaced the shoes and the master cylinder. After adjustthen up and bleeding the lines, we still have no brakes. any adivce folks??
  • Posted 19 Mar 2013 07:29
  • By marinadude
  • joined 19 Mar'13 - 3 messages
For best results I'd start a new thread w/ model & serial #'s & a complete description of your symptoms.
  • Posted 8 Aug 2014 23:11
  • By bbforks
...I know this is an old post, but what did you end up finding with your issue? We are having a customer with the SAMe issue! I brought the drums back today and cut them and it almost seems like it made it worse! All new wheel cylinders and brakes and brake hardware were done in Dec 2013 and customer said this just all happaned out of the blue. I will check the backing plates Swoop, and see if they are hanging up the shoes
  • Posted 8 Aug 2014 12:07
  • By ctforkliftguy
  • joined 14 Mar'13 - 48 messages
  • Connecticut, United States
so you have a tight pedal but brakes will not apply?
it sounds to me like some kind of problem in the wheels maybe?
did you check the backing plates when you replaced the shoes?
sometimes they wear grooves where the shoes ride and these grooves will actually keep the shoes from moving, even though you have a seemingly good pedal.
try pulling the wheels & hubs and rechecking this
if you do find worn grooves on the backing plates they will have to be replaced.
I would also double check the hardware configuration and make sure your guys got it put together correctly, make sure the wheel cylinder rods are connecting to the shoes correctly etc.
  • Posted 20 Mar 2013 23:10
Have you used a DOT 4 or 5 brake fluid.
  • Posted 20 Mar 2013 03:56
  • By grubbymits
  • joined 25 Jan'09 - 49 messages
  • scotland, United Kingdom
i know when they pulled the drums off the old brake shoes had caused a "lid" inside the drums making it tough to get them off. they "dremeled" out that lip so my guess is they drums are smooth... Looks like the need roughed up.
  • Posted 20 Mar 2013 03:00
  • By marinadude
Yes it might, sounds like the drums are glazed heavily and need either scuffed up good to take the glazing off or better yet turned down just a bit to true them up and take the glazing off just don't turn the down past their max ID,this should be stamped someplace on the drum
  • Posted 20 Mar 2013 01:05
  • By kevin_t
So if I'm understanding you correctly, you have a good, high,hard pedal- it just doesn't stop when you stand on the brakes. Did you cut the brake drums, rough them up or do nothing at all to the drums? If you did nothing, this is the reason for your issue. The compounds of the brake shoes these days require the drums to be at least roughed up or they'll take forever to seat.
Scuffing the shoes isn't really the answer, I'd spend your time getting the drums cut. Even when you're done with that the shoes will still take some time to "bite"- this has been my experience. What brand of shoe did you install- Hyster brand or aftermarket?
  • Posted 20 Mar 2013 01:04
  • By bbforks
We replaced the master cylindr, wheel cylinder, shoes, everything.... We have pedal but you can stand on them and it still doesnt stop the truck. It is a S30XL. We were told to scuff the drum and pads in different direction? any idea if that will work?
  • Posted 20 Mar 2013 00:32
  • By marinadude
replaced the master cylinder but not the wheel cylinders? How did they look...also how did the drums look... scored? worn??
  • Posted 19 Mar 2013 08:13
  • By kevin_t
How tight did you make the adjustment on the brake shoes & how much freeplay is in the brake pedal before it contacts the pushrod in the master cylinder?
Is it an S30A or S30XL?
  • Posted 19 Mar 2013 08:11
  • Modified 19 Mar 2013 08:12 by poster
  • By bbforks
Terberg YT222
UN Forklift FB25N1QZ1
Sue Tomic Sue Tomic
