Brake problem komatsu FG10
I have trouble with the brakes of my FG10 komatsu. Somethimes I can put the padle to the bottom without braking? But somethimes is works. Could somebody give me a hint.
Kind regards
Carlo
  • Posted 12 Dec 2011 07:41
  • By carlootje
  • joined 11 Dec'11 - 4 messages
  • Gelderland, Netherlands
Is there some kind of power steering and if so how does this works? Like a car with a vacuum valve from the inled of the caburettor!
regards,
carlo
  • Posted 13 Dec 2011 07:19
  • By carlootje
first i should check for leaks in the circuit,if this ok, I would think in the master cylinder.
to remove any doubt will disassemble the wheels to check pads an brake cylinders.
Regards
  • Posted 13 Dec 2011 01:51
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Looks a bit strange too me, because if I hit the brake you feel totally nothing. It the pump is bad you should think that it would at least do something don't you?
carlo
  • Posted 12 Dec 2011 20:28
  • By carlootje
If sometimes the pedal works well and has no leaks could have damaged the brake pump.
Regards
  • Posted 12 Dec 2011 07:50
  • By nacsand_n
  • Madrid, Spain
Hawker Powersource, Inc.
Muncie, IN, United States
Deborah Baker Deborah Baker
