Blowing fuse
Have problem with truck blowing fuses in ignition circuit. will run for about an hour then fuse blows and truck stalls and won't start had to replace dash board cluster and key switch but problem is still there. need help please Thanks Rich
  • Posted 1 Sep 2008 03:27
  • By rich_k
  • joined 30 Oct'07 - 108 messages
If you need any help, i'll try to lend a hand, Rich [email address removed]
  • Posted 4 Sep 2008 06:45
  • By rich_k
another example of top quality workmanship there then. eejits
  • Posted 4 Sep 2008 04:09
  • By kevin_k
Thanks guys, it is a new customer. I went and found someone had added a shock switch and a strobe light and got power from the ignition coil. Thanks Rich
  • Posted 3 Sep 2008 11:46
  • By rich_k
check the wiring on top of transmission and round back of handbrake. don,t usually get many wiring problems with xl models. sounds daft but are you sure it,s not an xm. wiring is a nightmare on the xm. is it monotrol
  • Posted 3 Sep 2008 03:42
  • By kevin_k
I'll check that out tomorrow, Thanks Rich
  • Posted 2 Sep 2008 01:00
  • By rich_k
look for wires rubbing against the frame
get the serial number
what fuse is failing
what engine
  • Posted 1 Sep 2008 14:43
  • By justinm
Sue Tomic Sue Tomic
