blowing fuse #4
lift starts up and will run for a very short time ( 2 minutes) and then blow the start up fuse. This is an ac drive truck. Rewired the ignition harness, searched all over for a short and found none.
Replaced fuse this yesterday, ran lift for 20 minutes all was good,operator got on it and fuse blew ????
at the end of the rope... HELP
  • Posted 14 Sep 2012 22:10
  • By warehouser
  • joined 14 Sep'12 - 1 message
if you want to risk burning up the wire harness then by all means throw a larger fuse in it. (of course i'm not being serious so dont try this)
But....
If you want to find the problem with no risk to damaging the truck further then the correct course of action would be to backprobe the system starting at the fuse and locate the shorted wire or component. Performing an OHM check sometimes is not enough, you might have to do a resistance check on the circuits in question instead which requires more time but can be more effective in locating your problem. This may also require using the wiggle test, moving the wiring around with leads connected to try and duplicate the shorted condition.
A wiring diagram would be extremely helpful to keep you from doing any unnecessary probing in areas unrelated.
From the sounds of it this problem may be wiring related since it only does it while its running, a chaffed wire moving around rubbing on the truck somewhere can wreak havok on troubleshooting effectively and will drive you nuts till you find it.
Good luck
  • Posted 27 Sep 2012 21:14
  • Modified 27 Sep 2012 21:16 by poster
is this a control fuse that is blowing probably 10-15 amp agc fuse if you are at the last resort stage put a larger rated fuse say a 30 amp drive it till you see the majic smoke show where the short is.now be advised you can create more damage if the short is in the wiring ,if it is a component the short should stay isolated to that component good luck.
  • Posted 27 Sep 2012 14:12
  • By toyrayown
  • joined 25 Sep'12 - 5 messages
check unused connector at master controller area for battery acid causing short circuit
  • Posted 27 Sep 2012 02:16
  • By Autodog
  • joined 27 Sep'12 - 12 messages
transposing nr for hyster please
  • Posted 16 Sep 2012 17:15
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
Terberg RT403
UN Forklift FD40T
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Justin Byma Justin Byma
VP global product manager and strategy , Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
