Bleeding out brakes after replacing the master cylinder
Hey guys,
I just had the master brake cylinder replaced on a c300-40 clarklift. The rear seal was leaking. It is the one located under right side frame. Now with the new one very little air bubbles come out every several minutes and there is no brake at all.
The old cyl was leaking all the way dry but always worked after refill.
Any help with how to properly bleed it out would be very much appreciated.
Thanks!
  • Posted 31 Jul 2017 02:37
  • By dim_p
  • joined 15 Aug'15 - 6 messages
i use a method on cars/trucks that may help you out. The vacuum method, applying a vacuum to pull the fluid from the master cylinder. Your local auto parts place should have a simple device. I made my own, using an ac vacuum machine, a gatorade bottle and some clear plastic tubing.
Pic: www dot BacliffRV dot com/Truck/Rear Side.jpg
  • Posted 31 Jul 2017 03:13
  • By Jetty
  • joined 12 Mar'17 - 44 messages
www.BacliffRV.com/Toyota_Forklift
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Aichi SR18A
VETTER Forks, Inc.
Alogotransiphobia is the fear of being caught on public transport without a book to read.
