Bleeding injectors
Have no codes, all inputs seem ok to computer, fuel at lines when cracked at injectors cranking but no injector pulse or fuel coming through return lines. Anything odd about them? This is happening to 2 units and 2 different companies locally that both just had engines rebuilt. 1.9tdi. Will run on wd40. Ran fine before removed. Injectors not spraying have had lines reattached to pump and out of head and they don't spray, only one pulse has been seen out of them.
Thanks
  • Posted 6 May 2020 11:32
  • By Louichman
  • joined 1 May'20 - 5 messages
In the end, the injectors had issues and the cam was out half turn to pump timing.
  • Posted 7 Jul 2020 21:59
  • By Louichman
After using a vacuum pump to pull fuel through the return lines its now starting. Would not start with just cracking lines at injectors but its a bit lazy so the pump or injectors may have an issue, Glow plugs turn on properly and are all new
  • Posted 11 May 2020 10:49
  • By Louichman
Is the heater plug light flashing all the time your trying to start the engine???
  • Posted 11 May 2020 04:44
  • By lifter01
  • joined 4 Jul'09 - 465 messages
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
