battery theory for forklifts
Hello
I would like to know how do we rate a battery with its AH rating.
I have seen a forklift with a drive power of 5.5kw and pump power of 7.5kw and having a battery of 48V/500AH and it says that the battery will last for 5 hours.
but if we go to see then 5.5+7.5=13kw and for 5 hours=65kwh for both motors
whereas the battery power is 48*500=24kwh. so how can the forklift even run for 5 hours or so?
and even if we aassume that they wil not run at full speed all the time and if we divide the 13kw/2=6.5kw and for 5 hours=32.5kwh and still the battery is not sufficient
so is my calcualtion wrong or am i missing some parameters
  • Posted 3 Sep 2011 15:57
  • By vadi
  • joined 3 Sep'11 - 5 messages
  • 1, Italy
Is it possible the 5.5 kw & 7.5kw ratings might be in reference to the motor power? - which is typically stated as kwH (metric system) or, HP in English system. Motors are general rating in terms of power and max ampere draw. Batteries are measured in voltage, max amp per positive plate & number of plates per cell.
Motors consume the most amperage when the are operated under load - like initial start up while driving (it takes very little power to maintain a travel speed or trying to "chisel" the forks under a load or when lifting or tilting or side shift a capacity load.
All batteries have an amp rating at a 5 hour or in N. America 6 hour rating. This the amp rating per positive plate in each battery cell. Batteries of the same physical outside size can & do come in various amp hour ratings - the greater the rating the more expensive the the battery. Sometimes decisions are based on economics vs actual need. Meaning batteries are very expensive these days due to lead prices and more than doubled in price in the last few years.
If you wish to know what the amperage draw is in your operation there are instruments to record it. They are connected between the battery & the truck & records amp draw over your works shift. The name of the device in the is called a "Power Prover" in the US but you local battery dealer should know what it is in your country.
  • Posted 5 Sep 2011 03:41
  • By johnr_j
"Have An Exceptional Day!"
Tusk 500PGH16
SMV (Konecranes) 4632CC5
