BATTERY LIGHT illuminated on Dash
Having trouble figuring out what is causing the battery light on the dash to illuminate. Battery holds a good charge of 12.6v. Alternator is charging at 14.1v. Haven't found any broken wires along the harness. But harness runs off alternator and spiders out into and air intake sensor, then up into the overhead gard and I'm assuming back down the other side. Please advise.
  • Posted 2 Jul 2024 02:01
  • By Damian_Smith
  • joined 2 Jul'24 - 1 message
  • Arizona, United States
Damian Smith
It is possible the regulator inside the alt has a bad bridge rectifier that would keep the bat tery light on and still charge the truck
  • Posted 2 Jul 2024 11:13
  • By Scott_
  • joined 16 May'21 - 344 messages
Scott
edition #1299 - 17 September 2026
With the world changing, in seemingly too many ways to fully comprehend, businesses need to be agile enough to change with it... Continue reading
The dot above a lowercase "i" or "j" is called a tittle.
