Battery light flashing at 0 will not lift
has 4 new batteries. when you unplug from the charger it shows 100 percent and machine operates normally. If you use it for 5 mins then shut it down and restart it it goes back to 0 even though the input voltage is still 25.6V. Then I have to plug it back into the charger to get voltage back up to 26V and it will work again until I shut it off and restart it. Is there any way to adjust or bypass the lift shut down voltage it seem to be triggered as soon as the surface charge is off the batteries. Thanks for any advice in advance
  • Posted 28 Sep 2014 05:20
  • By flaminghoop
  • joined 17 Feb'10 - 5 messages
  • British Columbia, Canada
I did what you said and parameter 21 is set to 8. If I can get a can key do I want to go higher or lower to make it accept lower than 25 volts as a charged battery pack. I checked it again and the batteries are 25.3 volts at rest and 24.3 while lifting 4000lbs
  • Posted 29 Sep 2014 03:28
  • By flaminghoop
Not with the keypad, use display and throttle grip. The Can key is a tool the Tech carries in his truck, it's never left in the lift. Basically a red box with a plug. You can change the first ten parameters without the Can Key. power off truck, hold down horn button while turning on key again. keep holding horn. Look at display, it will scroll betweem hours, codes, parameters. When "P" is showing, release horn button. Now twist grip and let go. You are seeing parameters 1 to 10. Actually you will see all, til 40....but you cannot change the ones over 40 without can key. Par 1 is top speed in slow mode, par 2 is top speed, par 3 is accel rate, Par 4 is decel rate. To change speed, when par 2 or 3 is on, hit the horn button. the Value shown will flash, now twist the handle grip to increase or decrease speed. Be carefull and make note of each parameter before changing. If you mess up things and the truck crawls, or goes too fast, you can put back to normal. A Raymond tech will have it, Do you know any?
  • Posted 28 Sep 2014 14:00
  • By EasiTek
How do you change parameters with the key pad? The is 2 wires with a plastic jumper and a round resistor looking thing glued to the side of the connector. Any chance that is the can key?
  • Posted 28 Sep 2014 08:59
  • By flaminghoop
A can key is just a two inch square piece of plastic with a round pigtal. Yes, you change it by the throttle and display, but parameter 21 wont change unless you connect a can key, inside cab on top left. You can change other parameters like speed, without can key. Did you know how?
If you were not so far, i could lend you one. I could get to England faster than BC!
  • Posted 28 Sep 2014 08:25
  • Modified 28 Sep 2014 08:29 by poster
  • By EasiTek
The problem started about a month after installing new batteries. Batteries are lead acid. Which was what was in it before. Battery cells are all even at 1275 sg. Batteries maintain 25 volts under load. At rest they are 25.5v at the line contactor. What is a can key? Is there any way to change settings with the keypad?
  • Posted 28 Sep 2014 08:21
  • By flaminghoop
This problem started only after new batteries?
There is a parameter 21 for different types of batteries. It is from 1 to 20, with default at 8.
You need CAN key to change this
Did you replace with same type? Style?
What is voltage when you re-start....still at least 25.3?
May have a bad battery...so commom
  • Posted 28 Sep 2014 08:05
  • By EasiTek
