Battery charge suddenly drops to zero
There is nothing on this issue in the service manual. The lift will be working fine with charge between 30 and 70% and if turned off and back on the charge will read 0. It is very intermittent. Usually we turn it off and then back on once or twice and it resets. Sometimes we have to get it on the charger for a few minutes and then it will reset. The battery charges and holds charge except for this.
  • Posted 22 Nov 2019 05:22
  • By DAVID_MEIER
  • joined 22 Nov'19 - 2 messages
  • Kentucky, United States
Distilling Dude
Hey David - did you figure out what the issue was? Mine is doing the same
  • Posted 28 Jan 2020 04:55
  • By Steen_Olafson
  • joined 28 Jan'20 - 1 message
  • Alberta, Canada
Steen o
