Bad idle
I have a unit that idles bad(hunting) and I cleaned the throttle body, but still have the problem. now it has fault codes E05-1 and E05-5. Please help. Thanks
  • Posted 4 Dec 2013 22:30
  • By jim_v
  • joined 26 Aug'08 - 61 messages
  • Michigan, United States
moisture in the throttle body. dry it up or let it sit for a while. it should disappear. take the plug out of the vaporizer and adjust it.
  • Posted 17 Mar 2016 23:27
  • By jim_v
did you ever find the problem? I am having the same issue
  • Posted 17 Mar 2016 22:51
  • By shaun_p
  • joined 14 Dec'12 - 15 messages
Will try that tom., Thanks for the input.
  • Posted 5 Dec 2013 10:17
  • By jim_v
You may want to check the throttle position sensor under the accelerator pedal. You may want to drain the lp regulator and remove and clean the air-fuel ratio assembly. It is on the side of the air horn, held in by 2 Philips screws.
  • Posted 5 Dec 2013 10:04
  • By rogeriwt
Toyota 02-8FD30
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Toyota 02-8FD30
USD1
Toyota 02-8FD30
USD1
ROYPOW
