Hi Guys,
One of our customers has an Atlet UNS 200D (double deep reach truck) Every morning when he turns it on, it comes up with error code E71, If he tries the Hydraulics 1st, the machine shuts down on code E105.... If he tries the traction 1st, it shuts down on error code E106. Whichever order this is done, after one or two resets on the ignition keypad, the truck comes on, stays on and doesn't fault for the rest of the day. This fault is the same every morning and as regular as clockwork. Does anyone know where I might find any answers or possible Technical assistance please?
Cheers in advance of anyone who can help. Iain
Hi, can you also check Error E35 for Atlet UNS 160? The reverse and forward arent working.
If you are still having problems with logging on in the morning then you need to add resistor in series with key relays. Let me know if you need more info.
From Admin....
Someone (anonymous) asked the following;
Can someone help me with meaning of error code E50 found on my UniCarriers reach truck forklift.
Cheers
Admin
Hello
For E71 is normally that you get block functions on that truck.E71 is low output(probably something charge slow and that is every morning)from reason that I know Atlet UNS system my advice for you is to call dealer to fix this.Of course that is only advice and we all try without them but I tell you only for safety reason.You need some special tool also.Mail me if you need more something.King Regards and good luck
