All cylinders drift down
On my Toyota serial number 62460, all lift cylinders are drifting down. I'm assuming it's some sort of check valve somewhere. Does anyone by chance have a hydraulic schematic or ever ran into this issue before on this lift. They recently had a piston explode in the lift cylinder and metal debris went everywhere in the system, filter and fluid has been changed. I'm sure there's still shrapnel in the system though. Thanks!
  • Posted 17 Jan 2025 09:50
  • By Michael_Brown
  • joined 17 Jan'25 - 14 messages
Bottom of cyl and most cyls have one
Some screw in and some have a snap ring
If you do have to replace be sure you get same ones they are usually marked with a number on them
  • Posted 2 Mar 2025 11:10
  • Modified 2 Mar 2025 11:11 by poster
  • By John_Bradley
  • joined 10 Aug'22 - 292 messages
Jb69
Is the pressure relief valve at the bottom of the cylinder or in a manifold block on those trucks? If in the cylinders does each cylinder have one?
  • Posted 2 Mar 2025 10:45
  • By Michael_Brown
That happened on a few Linde lifts back in early 2000 I had several that did that the relief valves were failing causing metal to get into whole hyd system we had to clean all hyd system and we actually had to replace the control valves because the Linde was such close tolerance I hope you don't have a relief valve issue also
  • Posted 2 Mar 2025 06:18
  • By John_Bradley
Jb69
Yes I pulled out the control valve took it to a hydraulic shop for a complete rebuild. He sent me pictures, multiple torn seals and even some damage to the spool valves. He found lots of metal debris in there. I will update if it helps. I'm sure it won't hurt it
  • Posted 2 Mar 2025 05:04
  • By Michael_Brown
I read your post l see everyone gave you good advice. I guess l will chime in. I would find the main lift line to the control valve install a gate valve in line raise the mast up then close the gate. see if the cylinders stay up with the gate closed that will tell you if the hyd oil is getting past the control valve. good luck.
  • Posted 2 Mar 2025 04:59
  • By Scott_
  • joined 16 May'21 - 330 messages
Scott
Did you replace pressure relief in cyls ?
If not could be your issue also when metal gets into system it gets into hyd control valve you may end up removing and thoroughly cleaning it also
  • Posted 26 Feb 2025 03:55
  • By John_Bradley
Jb69
You may have to remove the hyd control valve and thoroughly clean it.in most cases you have to replace, small metal pieces inside could be holding dump valve open did you replace the pressure relief valve in cyl if not that could also be an issue
  • Posted 26 Feb 2025 03:53
  • By John_Bradley
Jb69
I'm dealing with the same issue. If you fix it, can you let me know what you did? Thanks!
  • Posted 24 Feb 2025 02:06
  • By marcos_m
  • joined 25 Feb'19 - 114 messages
Pull out down valve..follow the connecting rod to valve body...I'm sure it's not seating correctly, you can attempt to rebuild but I recommend a replacement
  • Posted 18 Jan 2025 06:49
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
Justin Byma Justin Byma
VP global product manager and strategy, Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Taylor THC500L
Taylor TXB180S
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
