alarm 1 traction alarm 1 lift
HI, I am getting alarm 1 on both traction and hyd controllers. Battery voltage is fine as are fuses. I am getting my 48v pos supply to the contactor but don't seem to be getting the neg. Anybody any ideas of where i could be losing the negative or why my main contactor is not being supplied the neg. My traction controller is testing ok.
Thanks
  • Posted 20 Oct 2012 03:00
  • By diesel123
  • joined 10 Jun'09 - 20 messages
  • antrim, United Kingdom
Hi Diesel,
Is the main contactor coming in,truck will still light up the display even if this doesn't come in,obviously make sure you have 48v both sides of the contactor,or at the 2 main heavy fuses,as they're sealed you can't actually see tips,so will need to check with a meter,and have you also checked the small microswitch on the side of the emergency disconnect?
  • Posted 29 Aug 2014 04:09
  • By spannerboy
  • joined 31 Jul'13 - 12 messages
as a general rule, negative is supplied through the controller.
  • Posted 4 Aug 2014 10:14
I have same problem....
  • Posted 4 Aug 2014 08:59
  • By jollydjoger
  • joined 8 Jun'13 - 23 messages
  • Sofia, Bulgaria
SMV (Konecranes) 33-1200C
SNORKEL A46JE
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
