abnormal hydraulic noise
Serial 1A229402. Heres one for everybody. Service call for "funny noise". I raised carriage and when you let go of control handle theres a quick fluid rush to the resevoir. Return hose at right side side resevoir that tees into steer torque generator and T1 tightens or flexes. Definately from that source. Seemed to be a restriction so filter was changed. same noise. has old style filter housing. Top/cap was changed from another unit. defect remains. Resevoir is venting o.k. at left resevoir. Although there is no affect on function, just seems odd. Possible housing/screen clogged?? Comments and help appreciated.
  • Posted 18 May 2010 11:55
  • Modified 18 May 2010 11:56 by poster
  • By tonymfg
  • joined 16 Jan'09 - 43 messages
  • New Jersey, United States
check the return hose within the tank
  • Posted 22 May 2010 09:58
  • By CGMI
  • joined 25 Nov'09 - 15 messages
  • Illinois, United States
no. does not pop up. Have not returned to customer for follow-up.
  • Posted 20 May 2010 10:32
  • By tonymfg
Does the "RED" button pop-up when it makes the noise?
  • Posted 19 May 2010 09:40
  • By Truck_Tech
  • United States
