8400 error code 202
I have a truck that randomly throws an e 202. Sometimes as soon as it keys on. Other times after it sits keyed on for 20-30min. Battery does not drop below 23v per dvom. I know its got something to do with the traction control or ecr. Looking for some common places to look before ruling out parts.
Thanks Jim
  • Posted 13 Sep 2016 00:19
  • Modified 13 Sep 2016 00:20 by poster
  • By Tech2
  • joined 13 Sep'16 - 1 message
  • Illinois, United States
traction amp current sensor code...
23 volt drop...you tested with Fluke meter on MIN/Max ??
May drop to 17 volts for a milli second...need min/max setting to test or you wont see squat
otherwise it is not a valid test
Load test battery...is it always the same bat?
If so test it when low, bad battery shows up better
watch volts as you lift and acell at same time
check connections at motor and Amp...any signs of heat or discoloration warrant a cable change
Check fuses, they get weak, burned. voltage drop accross fuse will test
no more than.5 volts
other than that its a VM
  • Posted 21 Sep 2016 14:51
  • By EasiTek
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
UN Forklift FGL18T
UN Forklift FBR25NQC3
