6CYC CONTINENTAL ENGINE OR OTHER
IS THIS A CONTINENTAL G195 ?
  • Posted 3 Sep 2016 05:50
  • By WRPS
  • joined 3 Sep'16 - 5 messages
  • Arkansas, United States
That last number off of the frame from the right side of the seat is the trucks serial
  • Posted 19 Jan 2017 05:06
the only numbers i can find on the dash tag.. type G.....193A or 195A....on the right side frame beside the seat rail B3D10509 S. Cant find any other numbers ?
  • Posted 19 Jan 2017 03:17
  • By WRPS
WRPS,
You will need to provide a full serial number there are to many options and production breaks on these trucks.
  • Posted 7 Sep 2016 21:39
  • By Partsguy5
it is the continental 4cyc, and its on lp, it has started running hot,. there is two small cracks in the radiator top, so i likly need a replacement, and water pump. where can i find parts?
  • Posted 7 Sep 2016 00:37
  • By WRPS
yes i suppose it could very well be a G193, depending on the year it was manufactured. The data i got was for older models that used the continental engines.
Like i said, without a full model and serial number it would be impossible to know unless i got a direct look at the engine dataplate.
  • Posted 3 Sep 2016 22:38
The Hyster H40F that I service does in fact have a Continental G193, not 195 engine. It's a real odd ball.
  • Posted 3 Sep 2016 10:46
your right,, i miss typed its a 4cyc,, hand scratched number says g195 cont
  • Posted 3 Sep 2016 08:05
  • By WRPS
is it a flat head engine?
if yes then yes it is a continental engine, in a H50H i doubt it is a 6cyl tho, those weight class trucks only had 4cyl engines in them. The 6cyl engines didnt go into any truck less than a 7000lb series if i'm not mistaken.
They were usually Y112 or F162 series 4cyl engines in the 6000lb or less trucks.
And in the larger trucks they used the F163, F226, F227, F244 and F245 6cyl engines.
These were ALL inline bore engines, none of the 6cyl had v blocks.
if not a flat head engine then it is most likely a ford
The common ford engines they used to use were:
Ford 172/192 industrial engines and are also known as the Ford RSG428 and RSG431 series.
They may have also used a Ford 300 industrial engine which is also known as the Ford CSG649 series engine. I do not recall seeing many if any of these in hysters.
And of course the ford industrial engines do not have a flat head style engine, they have a normal valve cover.
Without a complete model and serial number of the truck in question it would be difficult to say which engine you have specifically.
  • Posted 3 Sep 2016 07:41
  • Modified 3 Sep 2016 07:42 by poster
edition #1237 - 3 July 2025
Hangcha CBD15
China
USD1,600
Hoist Liftruck F180-36BOX-CAR
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
SMV (Konecranes) 4535TB5
Taylor T520M
