524223-0 xmsn reverse perssure
Hi. I can't find the sensor in the gear box. Please send to me a picture from the sensor to my [email address removed]. Rezahamzavi1370
  • Posted 26 Dec 2021 18:03
  • By Reza_Hamzavi
  • joined 26 Dec'21 - 1 message
  • Iran, Islamic Republic Of
Reza,
The transducers are side by side. Switch one for the other. If code changes, transducer has failed. If not, most likely a failed connection or broken wire. Could be clutch pack, but unlikely. Good Luck.
  • Posted 31 Dec 2021 06:10
  • By Fishmech
  • Virginia, United States
The sensors that you are looking for are called transducers there are two of them one for forward and one for reverse they are in the trans valve body they look like oil pressure switches hope this helps
  • Posted 30 Dec 2021 11:38
  • By Scott_
  • joined 16 May'21 - 339 messages
Scott
