48 volt truck only runs on 36 volts
Serial A814N02928B
This is a 48 volt unit. Has new battery and new charger. Both set up correctly. Customer ran unit extremely dead. got battery charger and equalized and unit will not run on 48 volts only 36 volts. When on 48 volts it reads voltage too high. had controllers inspected and they passed. hooked up handset and tried adjusting function 15 with no change. looked all over truck and unable to find any sort of dip switches. are there any dip switches in the controllers? is there something Im missing? or any other tests I can do? thanks for any input
  • Posted 24 Sep 2021 02:41
  • By jordan_wiebe
  • joined 24 Sep'21 - 1 message
  • South Dakota, United States
jw
From what I'm reading you don't have parameters set correctly.
  • Posted 27 Sep 2021 03:10
  • By forkliftpete
  • joined 19 Nov'14 - 24 messages
Pete
Crown CG33P5
UN Forklift FL20-32LNJX2
