3e tm error
Ive been going back and forth between clark all week, transmission wont go into gear after removal and replacing the torque converter seal and oring on pump in troque converter. Had to split the transmission case take out gears which was simple. after putting it back to gether I Get 3e tm error, it was going into reverse even in foward and reverse. now it wont go into gear at all we have changed all speed sensors and output speedsensor/ eletronic gear selector sensor. checked voltage a communication. everything comes back like it is suppose to. I am struggling with this one. We have double checked all wiring to connections on solenoids they are were they are suppose to be, just incase you thought that was the reason it was going into reverse in foward.
  • Posted 26 Mar 2023 10:20
  • Modified 26 Mar 2023 10:21 by poster
  • By Austintrilift
  • joined 14 Sep'22 - 2 messages
Austin Georgevich
I have a workshop manual if you need it.
  • Posted 31 Mar 2023 20:26
  • By andrew_k
  • joined 17 Mar'07 - 365 messages
  • England, United Kingdom
The inching potentiometer can cause this. If it's bad, it will not let the transmission go into forward or reverse.
  • Posted 31 Mar 2023 01:55
  • By Slingshot
  • joined 31 May'19 - 3 messages
  • Kentucky, United States
Michael H. Baugh
Rail King RK330
Autolift E180AT36B-D5-180
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
