24 volt model....
hi gents
ive brought home a 35rrtt198.
have been charging the (11x 2volt cell) battery with the worst cell isolated. it shows 23.6v (with surface charge included....)
im getting nothing at all at truck...no light, no movement, no sounds,(though i did briefly hear a motor spinning and a gurgling sound)...
after having read plenty here tonight, im going to start tomorrow by looking at the fuses, the cards, hydraulic oil level and maybe motor brushes...
any advice for a newbie is greatly appreciated!
ps. is this machine a goody?, ie, can be kept operational fairly cheaply?
cheers
pps was quoted 300 for the manual!!! omg!!
([email address removed])
(ohfortooatethreeforonethreefourtwo)
  • Posted 20 Mar 2018 22:42
  • Modified 20 Mar 2018 22:44 by poster
  • By craigo
  • joined 20 Mar'18 - 18 messages
  • Queensland, Australia
Showing items 1 - 20 of 20 results.
The date should be stamped on the mast
  • Posted 26 Mar 2018 01:53
  • By Ifixit
just confirmimg my machine has 1 lift motor...
that is the "second" motor i have been referring to..
it spins when i do joystick up and thumb button depressed...
so the critters chewed the wiring to the ev1 scr...
im starting to believe this machine to be really old!!!
s/n:38997
actual model:35rrtt198
how old is this machine pls?
  • Posted 25 Mar 2018 19:52
  • By craigo
pics and info recd. with thanks!!!
standby while i do my homework!!
  • Posted 25 Mar 2018 16:32
  • By craigo
The motors will run, but you need the valves to open to direct the oil in the right direction. We can send pics in the email. By the way, if your truck has 2 lift motors...it should be a 36v system
  • Posted 25 Mar 2018 11:29
  • Modified 25 Mar 2018 11:48 by poster
  • By Ifixit
so 23.6 volts after another couple of days charging...
run both pumps with bleed screws open as promised...and nothing.
q: should i be able to operate motors directly by manually operatiog the contactors?
  • Posted 25 Mar 2018 11:05
  • By craigo
in the a.m. ill run the pump with the bleed screw open{ram[s]}
unlikely that will help with the fwd/aft movement issue...
found a couple of solenoids...wonder how these are checked?
  • Posted 23 Mar 2018 23:16
  • By craigo
@gmail.com
  • Posted 23 Mar 2018 22:07
  • By craigo
cjwalker1970
  • Posted 23 Mar 2018 22:06
  • By craigo
i gave my mobile number in code the first msg...
my email i try again...
cjwalker1970
@gmail.com
yes got brakes bled i think cheers....
found a couple of bleed screws on rams...
air got released from one, then a squirt of oil...
ive got battery on charge so thats all atm...
i have just now remembered the sellers advice:
"there is a broken pipe somewhere under the machine..."
"machine is only partly working..."
  • Posted 23 Mar 2018 22:05
  • By craigo
Yes, that is the brake fluid reservoir, and you need dot5 fluid. On the side of the drive motor is the slave cylinder. Pump the left foot pedal a few times, hold it down, and loosen the bleed screw to get the air out of that system. This forum doesn't let you post pictures, how can I directly contact you?
  • Posted 23 Mar 2018 18:07
  • By Ifixit
ok so the small cylindrical aluminium reservoir is confirmed as the brake fluid tank...nothing like having a near 3T machine moving under gravity!!!
  • Posted 23 Mar 2018 14:49
  • By craigo
hmmm i wonder where dat pesky bleed screw is!!
  • Posted 23 Mar 2018 13:30
  • By craigo
so late yesterday, i removed the top cover from machine...
gasp!! found that come critters had made themselves a home inside!!
bless them, they had also chewed on a whole lot of wiring.
im guessing its the control unit...has appx 10 terminals on each side...got the wiring all back together now and still machine behaving the same.
now to locate some bleed screws!!
thanks!!
  • Posted 23 Mar 2018 08:33
  • Modified 23 Mar 2018 08:36 by poster
  • By craigo
Looks like you have to start cracking open some hoses and cylinder bleed screws to get the oil flowing again
  • Posted 23 Mar 2018 00:01
  • By Ifixit
the second motor spins but doesn't seem to be driving anything...
  • Posted 22 Mar 2018 19:44
  • Modified 22 Mar 2018 19:46 by poster
  • By craigo
the voltage stays above 19 but not by much...19.6 v.
dont think its enough...
i got it wrong earlier...
when the thumb button is depressed while moving joystick up,...a second motor,(in addition to steer motor) runs...
the trigger button cycles through the 3 modes but nothing from any...
  • Posted 22 Mar 2018 19:43
  • By craigo
Now that you have oil in the steer pump, are you able to reach, tilt, and sideshift?
  • Posted 22 Mar 2018 04:30
  • By Ifixit
yeah back again...
put another 5 l of hyd32 oil.!!
**** must have nearly been mt!!
pump a lot quieter now.
if i depress the thumb button and go down on joystick, a second, higher speed pump runs...nothing moves as a result though...
  • Posted 21 Mar 2018 20:38
  • By craigo
Thanks the swift reply!
Beginners mistake!, must stand in truck to get the pump gurgling...
put 5 lt of grade 32 hydraulic oil in tank and still gurgling......****!
ill check what the volts drop to...
i think 4 of my 12 cells are crook...
the pump that i can hear running is the steering...
nothing fwd or backward, up or down as yet....
only the steering so far.
  • Posted 21 Mar 2018 18:44
  • By craigo
Surface charge seems sufficient, but after turning the key on... what voltage drop do you get? If it drops to 19v, the truck will not work
  • Posted 21 Mar 2018 14:47
  • By Ifixit
edition #1237 - 3 July 2025
Columbia, SC, United States
Saratoga, United States
East Syracuse, United States
Toyota 8FBE20U
Flesherton, Ontario, Canada
Toyota 02-8FD25
Noblelift
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
