2000 Yale NR series reach truck - Sometimes get error at reverse
Low hour truck, but put joystick in reverse and sometimes it won't move for a few seconds, red warning triangle comes on and says "See error code". But then it always goes away and reverse does work after another second or two...but it is annoying that it hesitates so often.
When the display says "see error code"...where the heck is the code ? I don't see it on the display and I sure hope it doesn't mean the code on the MIB unit as that would involve removing the entire dash panel just to see the MIB... and by the time the panel was removed the code would be gone anyway I presume.
  • Posted 18 Sep 2013 02:57
  • By Milacron
  • joined 25 Nov'06 - 80 messages
OK, I'll answer my own question. Looked in the shop manual and sure enough the error codes only show on the MIB module...which means removing the entire plastic dash cover just to see the code. I guess I could cut a rectangular window in the plastic so I could see the MIB without removing the dash if it keeps happening, but I guess the theory is you might as well have the dash off if looking at error codes as you will probably need to remove it anyway to fix whatever is the actual problem the code is pointing to.
  • Posted 20 Sep 2013 21:16
  • By Milacron
Terberg YT223
Toyota 8FGC35U-BCS
Flesherton, Ontario, Canada
edition #1243 - 14 August 2025
In this week’s Forkliftaction News , we look at more financial reports with one major producer recording a “significant” decline in Q2 bookings to report an operating loss of USD8.5 million, while another had a strong quarter “despite increased trade tensions and a challenging geopolitical landscape”... Continue reading
The black box flight recorder was invented by Australian scientist David Warren in the mid-1950s. While initially met with indifference in Australia, his invention gained international recognition, particularly in the UK, and is now a mandatory piece of safety equipment on all commercial aircraft.
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
St. Louis, MO, United States
Ottumwa, IA, United States
RAEDER-VOGEL
Terberg YT223
Toyota 8FGC35U-BCS
