1965 Yale 2500 lift capacity
Good morning,
Back looking for some help on my old yellar Yale. The hydraulic pump crapped the bed. It appears something went through it. The key is sheared at the drive pinion. The pump and internals are fine so it is rebuildable
Can anyone steer me in a direction as to a rebuild kit, or a refurbished pump? Or I have pictures but I'm hoping there may be some suggestions on how to make the internal gaskets.
Here is a list of numbers on the pump.
Yale
5112534
20920 OB
1H 31 RMK
Thx in advance for any input. Greatly appreciated!!
  • Posted 20 Oct 2018 01:31
  • By ADHD_Scotty
  • joined 22 Sep'18 - 8 messages
  • Alberta, Canada
I'm aĺl about the function junk!
I will! Thx so much for that! Was that serial # I gave you any help? Is that a valid number?
  • Posted 20 Oct 2018 10:00
  • By ADHD_Scotty
  • Alberta, Canada
Contact Hader industries, use part number 511253400. They supply rebuilt hydraulic components. Yale no longer supplies parts for this pump.
  • Posted 20 Oct 2018 07:36
  • By BREWSKI
Unless its hidden somewhere all I have is the pump # and this number which is stamped by hand on the top of the r/h side frame plate. K1523G
  • Posted 20 Oct 2018 02:41
  • By ADHD_Scotty
  • Alberta, Canada
Do you have a model and serial on the forklift? I am not sure if the number on the pump will help locate parts.
  • Posted 20 Oct 2018 02:34
  • By BREWSKI
