TVH's innovative battery devices - Exhibiting at CeMAT 2011 – Hall 25 Stand G19
- 28 Apr 2011 ( #511 )
Click to view larger image
Extend the life span of your battery
Batteries are the heart of each electric lift truck. As this part of the machine is so important, TVH will soon publish a new catalogue containing all information about batteries, battery chargers and accessories related to batteries. As a preview of the new Batteries, Chargers & Accessories catalogue, a smaller brochure on batteries and accessories is already available on: www.tvh.com/productspecials.
This Batteries, Chargers & Accessories catalogue gives an overview of what TVH can offer its customers: all types of batteries, connectors, filling systems, chargers, hydrometers, cables, safety products such as eyewashers, acid-resistant goggles and gloves,...
Battery regeneration
At the CeMAT 2011 exhibition TVH will also place two innovative devices in the spotlight. The first device is the battery regenerator. This regenerator allows you to give a sulphated battery a second life: after the regeneration you can charge the battery up to approx 95% of its capacity again. The device can prolong the life of all sulphated lead-acid batteries by up to 5 years: starter batteries, semi-traction batteries, high-power stationary batteries.
The regenerator can easily be operated thanks to an 8 inch LCD-touchscreen and all the data stored in its memory can be downloaded to your laptop by means of a memory SD-card or via USB-connection.
Perfect discharge and analysis of the battery
The second device TVH will introduce at the exhibition is the BDX-battery discharger. The discharger can be programmed to discharge via a precisely controlled constant current. The included free software also allows you to call up test reports of the discharge process. These give a good idea of the condition of your battery: the discharged Ah is displayed as well as the current, terminal voltage and time span during which this occurred.
We will exhibit at CeMAT 2011 in Hannover. Come and join us on stand G19 in hall 25. Every fair day Happy Hour with Belgian beer from 16h30 on!
Brabantstraat 15 - 8790 WAREGEM
Belgium
Tel: +32 56 43 42 11 - Fax:+32 56 43 44 88
E-mail: info@tvh.com
Web: www.tvh.com
ShopFront: www.forkliftaction.com/cards/tvh_196/default.aspx
TVH is a world-wide supplier with customers in more than 162 different countries. As a 'One-Stop Shop' the company offers a full service in lift trucks, spare parts, accessories and handling equipment with a guaranteed fast delivery at a competitive price. From the simplest hand trolley to the heaviest lift truck, from the smallest nut to the complete chassis. Regardless of the brand, type or year of construction of the lift truck, TVH always has a solution ready. TVH's unequalled know-how is reflected by a database of 16 million article numbers, of which well over 450.000 references are in stock.
