Economical and efficient self tipping bins
- 17 Mar 2011 ( #505 )
Type SSD Tipping Bin. Click to view the larger image
An economical and efficient solution for the collecting and disposal of industrial waste, self tipping waste bins allow the forklift operator to empty the bin without leaving the driver's seat.
Forklift Traders offers a comprehensive and affordable range of Self Tipping Waste Bins for your forklift.
The range consists of the following models:
A low profile, compact bin for use in confined areas. Suitable for loads of 1000 kg, the SSD Tipping Bin is well suited to production machinery such as punching machines for the collection of slugs etc. Heavy duty construction with self dumping ability, the forklift operator empties the bin without leaving the drivers seat.
Options available
  • Crane Lugs
  • Drain Valve & Strainer
  • Cast Iron or Rubber Wheels
  • Painted or galvanised finish.
For more information click to view the product catalogue
Type NSD Tipping Bin
The NSD self dumping waste bins for loads of 1000 kg. During transport, the forklift tines are positioned fully under the bin ensuring the forklifts full lifting capacity is utilised. To empty the bin the operator places the front feet of the bin inside the edge of the bulk dumpster, then drive backwards until the tines clear the pivot point and then raise to allow the bin to tip forward.
Options available
  • Crane Lugs
Type NSD Tipping Bin. Click to view the larger image
Type JSD Tipping Bin. Click for larger image
These are bulk capacity self tipping bins for heavy waste, with models available up to 5.4 cubic metres. Manufactured from 5mm plate and channel reinforcement, these bins have an enamel paint finish, and a SWL of 3000kg.
Options available
  • Crane Lugs
CSD Tipping Bin
The economical CSD bin for loads of 1500 kg, is suitable for most waste handling applications. Fitted with a drain plug and wheel brackets (wheels not supplied unless ordered), this nesting bin uses a minimum of space for storage and transport.
Options available
  • Rubber or Cast Iron Wheels
Type CSD Tipping Bin. Click to view the larger image
Type NTU Tipping Bin. Click to view the larger image
Suitable for loads of 1000 kg, the NTU heavy duty tip up bin is manufactured from 3mm plate and is fitted with fully reinforced edges. These bins are ideally suited to heavy waste including metal, timber and building site rubble. The release mechanism is activated by the forklift operator pulling the pull chord from the driver's seat.
Options available
  • Crane Lugs
  • Drain Cock & Strainer
Type SJW Wide Pocket Jib. Click to view the larger image
Type TU Tipping Bin
Suitable for loads of 1000 kg, manufactured from 3mm plate and has a lower profile which allows more versatility in confined areas. Features internal draw rope release mechanism, and custom built shock absorber designed to prevent impact forces being transmitted to the forklift during emptying. The pouring lip and smooth formed edges make this bin ideal for food industry applications.
Options available
  • Crane Lugs
Type JTU Tipping Bin
Suitable for loads of 1000 kg, this larger self tipping bin, for bulk capacity,is manufactured from 3mm plate and fitted with strengthening ribs. Powerful shock absorbers prevent impact forces being transmitted to the forklift during emptying.
Options available
  • Crane Lugs
  • Plastic Lids (for JTU 18 only)
Type JTU Tipping Bin. Click to view the larger image
Type ROB Rollover Bin
Suitable for loads of 1000 kg, the ROB bin has a smooth tipping action with minimal impact when emptying. The cut away front lip makes this style of bin ideal for tipping liquid product. To tip, the operator simply pulls the handle via a draw rope without leaving their seat.
Options available
  • Crane Lugs
Forklift Traders Pty. Limited - www.flt.com.au
Michael Carlin
International phone: +61 2 9897 5111
From Australia, phone: 1800 688 788
From New Zealand, phone: 0800 93 8000
For more product information view the product catalogue here; or click to view the Forklift Traders ShopFront.
