Ningbo Ruyi’s Full Electric Pallet Truck
- 16 Dec 2010 ( #492 )
In October 2010 Ningbo Ruyi added to its product line-up with the addition of its Full Electric Pallet Truck. The Model CBD20S, with its small turning radius and low height, will be widely used in narrow-aisle areas like narrow warehouse and small super markets etc .
Advantages:
  1. Advanced AC control system, eliminating the motor brushes.
  2. Triplex mast with Max lowest height of 1.38M at lifting height of 2.5M.
  3. Applicable in double pallet function while forks are lifting up.
  4. Double Lifting cylinder ensures stable lifting.
  5. Low-voltage protection system to extend the service life of battery.
  6. High-power electric controller and motor greatly enhance reliability.
  7. Special attention to the safety, with emergency reverse button in case of collisions, protects staff from harm.
  8. Equipped with circuit breaker in case of emergency to cut off the power supply.
  9. Side-way battery makes charging, replacement, and maintenance easy.
  10. Battery cover uses rocker-style clamshell, which is easy to check out the batter and add
    electrolyte.
  11. Rail-oriented lifting increases the stability and makes the truck more compact.
  12. New type of vertical driving wheel with:
    a. Turning Radius is only 135MM
    b. Low-noise .
  13. Easy maintenance of the handle.
  14. Convenient maintenance: the rear cover provides access to:
    1. Controller; 2. Driving Motor and Wheel; 3. Pump Station; 4. Cylinder
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email: ruyi@mail.hz.zj.cn, sales@liftool.com
Web: www.xilin.com
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
