New reach truck from Ruyi
- 18 Nov 2010 ( #488 )
Ningbo Ruyi has launched its new Fork Reach Truck Model CQDH15C with its compact design for the American market. It is ideal for use in narrow-aisle warehouses with deep racking system and has the power to perform all applications while ensuring the comfort of operators.
The special advantages are:
SAFETY AND PRODUCTIVITY:
  • Advanced AC control system eliminating motor brushes and directional contactors, which significantly reduces maintenance requirements. Intelligentized regenerative brake system increases overall truck performance by decreasing battery charge intervals.
  • Equipped with adjustable hand-rest, adapted to different operators.
  • Multi-function display: battery state, hour meter, fault indicator, etc.
  • Side battery with roll-out system is very convenient for replacement.
    The battery upside cover makes it easy to fill the battery.
  • Damping cushion for low-noise operation.
  • Built-in pressure relief valve protects the trucks from overload.
  • Deadman pedal.
  • Emergency power disconnect.
  • Stepless speed control.
STRUCTURAL:
  • Low centre of gravity ensures the stable operation.
  • The use of articulated drive system renders stable and smooth operation. Vertically mounted drive motor system has a small turning radius and is easy to maintain. The motor structure is water-proof and dust-proof.
  • The Scissor Reach Forks with both electric control and hydraulic control make operation stable.
  • Heavy-duty German masts.
SERVICEABILITY:
  • Low battery protection setting prolongs the battery use time.
  • CANbus technology reduces wiring complexity and increase reliability.
  • All pivot points have grease fitting and serviceable bushings, reducing component wear and extending component life.
  • Plastic hydraulic reservoir makes it quick and easy to check the oil level.
  • The back cover is easy to open for maintenance and adjustment of parts such as multi-valve, accelerator, controllers, etc.
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email: ruyi@mail.hz.zj.cn, sales@liftool.com
Web: www.xilin.com
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
