New Generation, New Expectation
- 12 Aug 2010 ( #474 )
Two months after the relocation to new plant facility, HANGCHA now is proud to formally launch the new generation, XF Series, to global market.
XF series is more than just good looking, although the XF is the best looking generation ever in HANGCHA 35 years of production. With the design concept of "Simple, Solid, Smart", the XF series, which is produced from extensive research and improved through thousands of tests, represent a true solution to different needs.
Its special features include:
High Productivity: Dynamic load sensing hydraulic steering system, efficient lighting system and lower fuel consumption combine together to provide increased productivity and to reduce operating costs.
By optimising transmission design, the power train provides higher efficiency. The fuel consumption is reduced by 10%.
Reliability: By focusing on enhancing reliability and reducing downtime, the XF series is equipped with new aluminum alloy transmission with full floating structure features, integrated vehicle controller system, etc.
Comfortable operation: In developing the new XF Series, comfort and ease of operation were carefully considered,
Safety: A wide range of technologies are applied to ensure absolute safety for both the operator and those in the surroundings.
Easy maintenance: User-friendly design facilitates easy inspection and servicing. Easy maintenance reduces the amount of downtime and helps to reduce cost also.
Environmental Friendliness: A lineup of powerful and clean engines and environment-friendly materials are adopted to help reducing the output of undesirable substances over the lifetime of the truck, while creating a cleaner work environment.
HANGCHA welcomes any inquiries. For more information, please check www.hcforklift.com
Click here to view the HANGCHA Shopfront
