The New Product Line from HYTSU GROUP
- 20 May 2010 ( #462 )
After ten years of development, HYTSU Group has improved its product line, parts management system and general application of technology, all of which is now being applied to a range of large-capacity forklifts.
S100 Series 1.5-5t Gasoline Powered (LPG) Forklift
  • Advanced technology and high quality manufacturing make it more comfortable and easy to operate.
  • Easy-open hood ensures good thermal insulation, noise absorption and shock absorption. This means easier operation and maintenance.
  • All the trucks comply with strict environment protection rules, and each forklift is equipped with overhead dual air filters and high quality NISSAN, MITSUBISHI, IMPCO engines and components.
  • Advanced heat dissipation technology and cooling system enhance the radiating capacity and increase the work capacity.
  • Automatic adjusting clutch systems improve gear shifting.
  • Overhead dual air filters and buffer device for transverse steering axle
  • LPG option offered.
S100 Series 1-10t Diesel Powered Forklift
  • The lifting system chain and the cylinder are fitted separately, providing wider visibility and improving operator safety.
  • Integral dual air spring supported hood and hook type plate improves heat insulation, noise absorption and shock absorption. This allows easier operation and maintenance.
  • With an improved hydraulic tube design, faster lifting is achieved.
  • Automatically adjusting clutch systems improve the gear shifting.
  • Advanced engine and heat dissipation technology makes it more stable at work.
  • Floating hood and buffer device for transverse steering axle improves shock and noise absorbtion and driver comfort.
S100 Series 1-3.5t Electric Forklift
This Electric Forklift uses 100% AC power and boasts the following advanced features:
  • The front driving tyres with double high performance, low noise, 3-way AC motors.
  • Power management guarantees optimal electric supply status in all operating conditions to balance performance and power consumption.
  • Belzoni Side shift and multifunction assembled instrument.
  • 3-mode power management with SME electronic controller.
    1. Economy mode for longer operation
    2. Standard mode balances performance and power usage
    3. Qualified mode for maximum performance.
S100 Series 2-3t Cushion Tyre Forklift
  • Engine Power: Gasoline/LPG
  • This forklift is designed to lift and transport materials in such industries as food, pharmaceutical, electronics and instrument, etc.
  • Widely used in warehouses and containers, this model is noted for its small size, small turning radius, lower gravity and good mobility.
  • When equipped with a high mast, the lifting capacity is usually bigger than other forklifts with the same capacity. This makes it more efficient.
Electric Pallet Truck
  • American CURTIS electric controller
  • Reliable imported hydraulic pump
  • European drive unit and DC motor
  • Large capacity traction battery and European command head
Self-elevator stacker
The SL4095 travels with your van, pick-up or trailer. One SL4095 can replace your tail-lift, hand pallet truck, stacker, ramp and swing lift. The SL4095 is capable of easily moving, loading and unloading palletised goods of up to 600kg. The SL4095 is easy and quick to transport, in your vehicle, along with the load so that there will be no unloading or reloading at your destination.
Independently powered by its own 12V electro-hydraulic power pack, the ability of the SL4095 to load itself into a van, pick-up or onto a trailer (with or without a load on the forks) is what makes the SL4095 so unique. An innovation that revolutionises the field of load transportation with Light Commercial Vehicles.
Heavy Duty Electric Stacker
Special features of Heavy Duty Electric Stacker
  • Two model for your option: Narrow/Wide straddle
  • Competitive cost for great performance
  • Reliable power pack
  • Big capacity BS standard traction batteries
  • Flexible and easy steering system
  • Fork over type narrow straddle
  • Wide control system
Contact Info
Phone: +86 021 5869 0003
Fax: +86 021 5869 2793
Contact Person: Li HuiYing
Email: info@hytsu.com
Website: www.hytsu.com
Address: No.1 Jilong Road, Waigaoqiao Free Trade Zone, Shanghai. 200131 P. R. China
Click here to view the Hytsu Shopfront.
