Vanguard Forks
- 25 Mar 2010 ( #454 )
CLEAR TRACEABILITY
Clear Stamping at the shank side with production date and series number, Steel Batch No..
RELIABLE SAFETY
Italian GNR Spectral Analysis System provides reliable Steel Certificate.
Robotic weld, offering the most stable welding quality and performance.
ISO standard three times Overload on EACH fork guarantee "No Break; No False Welding".
STRICT TOLERANCE
  1. Restricted <1mm Tolerance Criteria provides the best dimension and matching.
  2. Tolerance Backup Records on EACH fork provide reliable traceability.
GOOD FINISH
  1. Special two-step Shot Blast provides better surface and painting base.
  2. Special treatment on the Inside heel radius not only looks good, but also removes rough edges or other imperfections.
ONE-STOP SOURCE
We are the leading source of fork arms up to 40ton capacity
Contact:
Mr.Diguo General Manager
www.fork-arms.com
info@fork-arms.com
Tel:+86-571-81952851
Fax:+86-571-81952852
Click here to view the Vanguard Shopfront
