The new Kalmar DRF420-450L
- 17 Dec 2009 ( #441 )
We can see that new customers and new markets are opening up for container handling equipment. Some of these customers do not have the operational requirements that we offer with our current models, and some new applications will not need heavy and intensive usage of their machine.
We will ensure that we can meet this growing need for cost-effective, productive and flexible container handling. That's why we're proud to present the Kalmar DRF L Reachstacker - a streamlined machine with a streamlined price.
The machine is designed for container handling. Nothing more, nothing less. Its performance and functions have been specially developed for the day-to-day reality at terminals that form part of the continental distribution chain.
The hydraulic system and the drive train are adapted to the demands on performance, productivity and durability that you have for example on a second machine in your fleet or at ports and terminals with a medium capacity. The range of options also matches the needs of this type of businesses, and therefore you will not be able to choose from all the options available on the regular Kalmar DRF.
Lifting equipment
The extensive freedom allowed by the lifting equipment, boom and attachment, and its rotation possibilities, gives that the driver can improve the work efficiency of the unit, by not needing to approach the container from a 90 degrees position.
Instead, the container can be picked or dropped-off by the unit approaching from any angle <90 degree. And by rotating the spreader and reaching the boom to suitable length, the driver can handle the container from any position. As an additional advantage, the aisle width - driving space depth, needed - can be squeezed, as well. Wear on the machine and the working surface can be reduced if the reachstacker is used in the right way. Compared to a conventional forklift, a larger proportion of the lifting manoeuvre can be performed while the unit is stationary.
Containers can also be lifted and transported lengthwise, making it possible to deliver the container into and through workshop doors, port shed gates, etc in then low, longitudinal position. This can be a vital ability for the possibility of container stripping and stuffing inside the sheds.
Time is money
With the Kalmar DRF L you can count on low energy consumption and low maintenance costs. What it all adds up to is the fact that everyone who handles containers now has affordable access to the industry-leading lifecycle economy of operating a Kalmar reachstacker.
Time is money. So of course, the most expensive thing is a machine that stands still.
The whole idea of the Kalmar DRF L reachstacker, right down to the slightest detail, is to provide exceptional availability and durability. Rest assured, this is a machine you can trust. Day in and day out.
W: www.kalmarind.com
Click here to view the Kalmar Shopfront
Get in touch with Cargotec Sweden AB
Cargotec Sweden AB
+46 372... Show
Cargotec Sweden AB
Torggatan 3, 340 10
Lidhult, Sweden
Cargotec Sweden AB
