GOODSENSE 3.0 Ton LPG Forklift with NISSAN Engine ON SALE!
- 18 Jun 2009 ( #415 )
To thank our customers for the past support and to help attract new business partners worldwide, GOODSENSE has launched a special promotion on "G Series" LPG forklifts with Nissan engines.
Overview of these models:
Model: FY30B-R2 (LPG forklift)
Capacity: 3000 KG
Engine: NISSAN K25
Transmission: Automatic
Mast: 3-meter duplex mast
Tyres: Pneumatic
Fork length: 1070mm
Why choose an LPG forklift?
  • LPG forklift trucks operate efficiently, with no loss of power.
  • Lifetime running costs can be lower than electric trucks. LPG reduces engine wear. On average, the savings from running a forklift on LPG mean that the price of conversion can be recovered within a year.
  • Ideal indoors and out - even in the most sensitive environments.
  • No battery disposal problems.
  • No harmful fumes under normal operating conditions, enabling an operator to work in a safe and competent manner.
  • LPG forklifts have less exhaust gas emissions than diesel or petrol forklifts. In the enclosed environments in which forklifts usually operate, emission reduction plays an important part in the health of the workers and improved environmental hygiene, reducing the potential of damage to sensitive products.
Details:
Engine       <br />Click to Enlarge
Engine
Click to Enlarge
Engine - The powerful Nissan engine, imported from Japan, ensures GOODSENSE forklift trucks' handling performance and offers an intrinsically safe and efficient operation.
Gearing - Hydraulic gearbox and hydraulic torque converter use TCM technology, with a gear shift buffer and warning device for smoother, easier changes. This enables replacing the friction shim and pressure plate without opening engine bay for convenient and servicing.
Gearing<br />Hydraulic lifting system<br />Click to Enlarge
Gearing
Click to Enlarge
Hydraulic lifting system - The components of the system have high quality with oil cylinders produced by a specialist manufacturer which supplies products for aircraft. The oil pump is Japanese. All the components are optimised to enhance the stability of the system. And the 160-type mast is made of special steel. The roller assembly maximizes visibility and reduces wear.. In short, the performance is advanced, safe, reliable and high efficient.
Dashboard<br />Click to Enlarge
Dashboard
Click to Enlarge
Dashboard - Full electronic metering displays the performance of all the major parts. It also offers comprehensive monitoring of the forklift's performance.
Overhead Guard<br />Click to Enlarge
Overhead Guard
Click to Enlarge
Overhead Guard - A metal roof supported by posts at each corner of the cab helps protect the operator from any falling objects. A transparent plastic cover can guarantee the forklift driver good visibility during operating, while keeping them out of the elements.
IMPCO Convertor     <br />Click to Enlarge
IMPCO Convertor
Click to Enlarge
IMPCO Convertor - IMPCO is the most famous LPG convertor in the world. It offers the engine more effective power by converting the LPG fuel.
Wide View Mast - is the vertical assembly that does the work of raising and lowering the load. It is made up of interlocking rails that also provide lateral stability. The interlocking rails may either have rollers or bushings as guides. The mast is either hydraulically operated by one or more hydraulic cylinders or it may be chain-operated, with a hydraulic motor providing motive power. It may be mounted to the front axle or the frame of the forklift.
Wide View Mast<br />Comfortable Seat<br />Click to Enlarge
Wide View Mast
Comfortable Seat
Click to Enlarge
Comfortable Seat - Easy adjusting, super-smooth forklift seat reduces the jolts and shakes of the forklift. It features adjustable lumbar support to provide the operator more comfortable and freedom.
LPG Tank Bracket<br />Click to Enlarge
LPG Tank Bracket
Click to Enlarge
LPG Tank Bracket - Easy process for changing the LPG tank!
Click here to view the Goodsense Shopfront
