MasterTrak’s end to end connectivity service plans provide the right information
- 26 Feb 2009 ( #399 )
4 min read
MasterTrak is an asset management tool that communicates directly with the engine and any other critical equipment data points that provide business value. This creates a means to monitor faults and alerts in real-time, proactively resolving engine and equipment problems and reducing costly unexpected failures that impact your bottom line. CLICK HERE TO WATCH THE MASTERTRAK VIDEO. MasterTrak's end to end connectivity service plans provide the right information, at the right time to OEM's, Dealers, Service Providers and End Users.
MasterTrak's Standard Service Packages are a combination of services that gives you just what you need to get started monitoring and managing your on-site system. You gain the benefit of MasterTrak's solid foundation of software, databases and communications technology to bring all these features into one, seamless package focused on your business needs. These Standard Service Packages are filled with valuable features that act as your eyes and ears on site, manage your data, automatically notify you and give you reports to help you do your job.
These features include:
  • Automated Notification on Alarms and Faults
  • 24/7/365 Monitoring for Alarms and Faults
  • Access Fault and Alarm Details via the Web Center
  • Data Gathering and Management
  • Asset Displays on the Web Center
  • GPS Mapping and Tracking with Geo-fence Alarming
  • Real Time polling for Asset Data via On Demand Service
  • Standard Reports on the Web Center or via Email
  • Optional Coordinator based services from 24-7 Operations Center Staff
MasterTrak is the next generation of connectivity solutions that enable customers to:
  • Track the location and health of assets in real time
  • Reduce unexpected failures that impact the bottom line
  • Know how customers are actually using assets
  • Reduce the Total Cost of Ownership
Health of Assets:
The GPS mapping and Asset View shows the location, utilization and health of each asset in real-time as indicated by the red, yellow and green status lights.
GeoFence Manager:
The GeoFence Manager will be enhanced to allow for improvements in setting geofences around multiple assets. The current GeoFence Manager simply allows for viewing and deleting of multiple fences. The new GeoFence Manager will provide for more site based fencing allowing the user to set a site fence around multiple assets in a few simple steps.
Maintenance Management Module:
The Maintenance Manager module is developed that utilizes the latest information received from your asset (eg. Run hours), to calculate and notify you of any upcoming maintenance requirements. This module includes numerous features for managing asset maintenance schedules and reporting options.
MasterTrak's Maintenance Manager will allow you to track critical maintenance intervals by hours on the machine or time (days, months years) since the last maintenance. Alerts and Reports will allow the customer to plan upcoming required maintenance activities and alert on units that are overdue.
Features
  • Create Maintenance schedules to meet the OEM recommended intervals
  • User can add new maintenance intervals above OEM requirements
  • Alert on overdue maintenance intervals via Alarm Management System
  • Run Reports on 'Upcoming' and Overdue Maintenance.
  • Schedule intervals based on machine hours and time based intervals (i.e: yearly inspection)
  • Enter completed maintenance information
Remote Contract Management (RCM):
With our two way communications capabilities we can both send and receive commands and messages from and asset. Remote Contract Management is intended to provide users the ability to remotely send a signal to put the asset into Creep Mode. Creep Mode is defined and controlled by the OEM and RCM is only a supervisor message that enables the feature. This is not available for all users and assets and you should contact you MasterTrak account manager for more details.
Alert Management System:
The MasterTrak system currently includes an independent Fault Code and Alarm Management feature. The Alert Management System combines these two elements into one module providing enhanced management capabilities and numerous improved usability enhancements.
Notification Enhancements:
The Notification features allow for multi-level escalation options. Simply put the user can define a contact group to be notified for Alerts and timing of escalation to new contract group if an acknowledgement is not received. Many features including multi-level escalation and time delays are included.
Keypad display
  • Vehicle access ID control
  • Fully configurable pre-shift safety checklist through audio-visual display
  • Programmable fault warning lights
  • Flexible mounting locations and orientations
  • Ruggedized and weather proof
  • Large easily readable ½" display
  • Simple four button interface
Impact Sensors
The MasterTrak Impact Module constantly monitors driver performance. You determine the shock levels to be recorded. Vehicle impact can cause damage to multiple components, including costly damage to the mast/carriage. At the time of installation, the system is easily programmed to meet your specific needs and MasterTrak 's unique shock sensing capability allows for a variety of options at the vehicle. It also gives management direct visibility to adverse conditions experienced by the vehicle and the driving habits of each operator.
  • Easily programmable shock levels
  • Impact severity data recorded to identify abusive drivers
  • Real time audio indicators provide feedback to driver
Jeremy Lessaris
Mastertrak, Inc.
655 Wheat Lane
Wood Dale, IL 60191
1.630.350.9400
See our website at www.mastertrak.com
jlessaris@powergreatlakes.com
