Tailift Unveils All New Style
- 23 Oct 2008 ( #383 )
Arctic Hare - Shining Launch
Completely new design by Tailift R&D team.
Streamlined chassis, inspired by automotive styling to enhance looks and ergonomics.
Tailift's in-house R&D team of highly skilled professionals combines Taiwanese expertise and global innovations.
New features
  • A1-A4 Shock absorber
  • B1-B2 Invisible tilt cylinder
  • C1 Electrical forward/reverse switch
  • C2 Electronic valve
  • D1-D2 Brake pedal assembly
  • E Fuel cover
  • F Direction light switch
  • H Dashboard
  • I Transmission control valve
Fully hydraulic Steering Axle: Tight turning circle and smooth steering help the operator achieve maximum control and performance.
Suspension chassis
The design of chassis reduces vibrations and ensures comfortable operation for all operators.
Wide visible mast
Using Germany steel, this construction gives the operator better forward visibility, improves safety and reduces operational fatigue.
Transmission
The automatic transmission, developed by Tailift itself, lets you change gear and accelerate easily. In addition, the precise inching valve, not only ensure smooth braking, but also lets you move slowly forwards in full-speed operation while operating the hydraulic servo system. This boosts efficiency.
Specification
FD/FG20
FD/FG25
FD/FG30
Overall Width
A
1158
1158
1290
Outside with between forks
B
1025
1025
1150
Front Track Width
C
970
970
1055
Width of Double Forks
D
250
250
250
Width of Single Fork
E
125
125
125
Rear Track Width
F
985
985
985
Minimum Turning Radius
G
2170
2250
2415
Maximum Height
H
4220
4220
4220
Mast
I
3000
3000
3000
Maximum Fork Height
J
2000
2000
2000
Free-lift
K
80
80
80
Bracket Height
L
1220
1220
1220
Maximum Fork Thickness
M
40
40
50
Fork Length
N
1070
1070
1070
Spacing from Front Wheel to Fork
O
465
465
480
Track Width
P
1550
1550
1650
Rear Height
Q
445
490
470
Overall Length
R
3530
3575
3670
Ground clearanceat lowest point
M1
120
120
120
center of wheelbase
M2
195
195
220
Height of tail
S
290
230
240
Seat height
T
1140
1140
1210
Steering Wheel Ground Clearance
U
1550
1550
1560
Height of Overhead Guard
V
2110
2110
2140
Space of driver's seat
W
425~600
Front Wheel Size
AA
7.00-12-12P.R.
8.15-15-12P.R.
Rear Wheel Size
AB
6.00-9-10P.R.
6.50-10-10P.R.
Aisle width (for load 800×1200and 1000×1200)
Ast
3635/3835
3715/3915
3895/4095
Click here to visit the Tailift ShopFront
