RackDeflektor will be at the NSC 2008 Congress & Expo
- 18 Sep 2008 ( #378 )
RackDeflektor is looking forward to meeting with you at the NSC 2008 Congress & Expo which is being held in Anaheim, CA from 22-24 September 2008. We will be located at Booth 1426.
RackDeflektor stands out when competing against steel and other manufacturers of Plastic products:
  • Easier and faster to install than Steel! No tools required to install RackDeflektor
  • Installation cost 10% of steel guards. RackDeflektor's patented clip mount design gives a secure mount and makes inspections easy.
  • No concrete floor damage from impact. Saves $$$ in repairs
  • Mounts on any rack, including drive in rack!
  • Mounts at the most effective height for your operation!
RackDeflektor is better than the other plastic brands!
  • Narrow design does not restrict entry in the lower pallet slots
  • Works on any size and brand of rack. Different clips are available to assure a secure fit.
  • If you change or move your rack, removal and replacement of RackDeflektor could not be easier! Replacement clips available at reasonable prices.
  • If shelf beams are in the way, simply trim the thin sleeve around the beam. It does not inhibit the effectiveness of RackDeflektor
  • Does not require zip ties to secure to large rack.
Call
RackDeflektor
+1-630-590-3984
www.RackDeflektor.com
