MSE provides 45 countries with RollerForks
- 3 May 2007 ( #308 )
Since the introduction of the RollerForks, Meijer Special Equipment (MSE) has expanded its dealer network enormously. MSE, the world's largest producer of telescopic forks, has, with it's RollerForks, built a long list of references in the chemical, food and consumer industries.
These successful RollerForks can be used to load and unload containers without making use of pallets. RollerForks are very easy to use and don't need any hydraulics plus that they can also perform standard pallet activities.
A very large part of the market for the RollerForks is the handling of FIBC's. This is because bigbags can be pilled up stable and easily and can be put in containers two-high. Moreover the slipsheets aren't shoved and pulled as would be the case if one would use a push-pull system, therefore no disproportionate powers occur. Because RollerForks don't contain hydraulic cylinders, hinges, etc they need almost no maintenance.
For additional information, contact:
E-mail email@mse-forks.com
Phone +31 518 492927
Fax +31 518 492915
