ASHTREE GLASS - Innovative high-quality Safety Mirror for the forklift industry
- 8 Feb 2007 ( #296 )
The Ashtree MX943 is a safety mirror that has been designed to assist drivers and operators when reversing in nearly any workplace. Reversing any machine can be hazardous but with poor quality mirrors in poorly lit areas the job can become a greater hazard to people and goods than it need be.
The MX943 uses a high quality acrylic lens that comfortably meets the European light reflectivity requirements for road transport mirrors. This wide angle lens gives a large, distortion free image to the rear and on both sides of the machine.
Whilst the lens is of a strong, durable material the rest of the mirror also stands up to scrutiny. The main body is made of impact resistant ABS whilst the clamp is made from 30% glass filled nylon. This gives strength and flexibility where it is most needed.
Fitting and mounting will not be a problem either. The clamp will adjust to any number of positions allowing the mirror to fit horizontally, vertically or at any point in between. The clamp will fit any mirror arm between 10 and 20 mm. Ashtree Glass can also manufacture and supply a range of mirror arms for mounting mirrors.
Ashtree Glass will be exhibiting their range of products at the IMHX in Birmingham, England from the 13th to the 16th of March. You will find them in Hall 20 Stand G25 opposite TVH.
For more information please contact John Roper at john@ashtreeglass.co.uk or call 0044 1274 546732 or fax 0044 1274 548525.
Click here to view Ashtree Glass ShopFront
