Precision in everyday warehouse operations: Work more efficiently with the LIZZARD Premium
- 30 Oct 2025 ( #1254 )
In modern warehouse operations, speed, efficiency, and care are equally important. Damaged goods or delays caused by incorrect handling can be expensive. This makes it all the more important to have tools that facilitate the daily work of forklift drivers and at the same time ensure greater safety. One such aid is the LIZZARD Premium from VETTER.
User report
"I have been working with front forklifts in warehouses for many years. Over time, you develop a good feeling for handling the machines – but there are still situations where the work remains challenging: when pallets are high up on the shelves, visibility is limited, or you simply have to work quickly. This is exactly where the LIZZARD Premium has helped me a lot.
The green cross laser is clearly visible, even in bright warehouse lighting. This enables me to align the forks precisely before driving into the pallet, which makes a huge difference, especially at higher levels, where it is almost impossible to see the fork tips. I save time and avoid mistakes that could otherwise lead to damage.
It is even more effective in combination with the integrated camera. The screen in the cab provides a reliable overview at all times, even when visibility is restricted by the design of the forklift. This ensures greater safety and gives me confidence because I remain in control.
I was also impressed by the easy handling of the LIZZARD. Installation was quick and simple, and the battery lasts a complete shift without any problems. So I don't have to worry about breakdowns or complicated operations – the system just works fine and reliably supports me on every tour."
Conclusion
With LIZZARD Premium, VETTER has developed a tool that makes an essential difference in everyday warehouse operation: more precise work, greater safety, and increased efficiency. In addition to the premium version, which combines laser and camera technology, the system is also available as a pure laser version, LIZZARD Target, and as a camera version, LIZZARD Cam. This allows an optimal adaptation to the individual requirements of a company.
Get in touch with VETTER Industrie GmbH
+49 273... Show
Carl-Benz-Strasse 45
57299 Burbach
Germany
