Innovating tissue roll handling: Bolzoni Group showcases expertise at MIAC 2025
- 2 Oct 2025 ( #1250 )
5 min read
Bolzoni Group at MIAC 2025: advancing paper roll handling with specialized solutions for a dynamic industry.
The tissue paper industry is one of the most vibrant segments of the broader paper market, fuelled by growing demand for hygiene products, sustainable packaging, and high-speed converting technologies. As production volumes rise and product specifications become more refined, manufacturers and logistics operators are increasingly challenged to handle delicate, lightweight rolls with precision and care.
This evolving landscape calls for smarter, safer, and more efficient handling solutions.
And when it comes to forest product handling, AURAMO forklift truck attachments are the point of reference.
Bolzoni Group, with decades of experience and a specialized product line under the Auramo brand, is recognized worldwide as a trusted partner for manufacturers, converters, and logistics operators in the paper industry.
Thanks to close collaboration with leading paper producers, Bolzoni Group has developed deep expertise in managing the unique challenges of tissue rolls handling. These products, characterized by high-volume and low-density composition, require exceptional care during transport and storage due to their sensitivity to pressure. This understanding has shaped the development of tailored solutions that combine efficiency with product protection.
See you in Lucca – Tuscany’s beating heart of paper
Bolzoni Group confirms its strong presence in the tissue paper sector and exhibits at MIAC 2025 International exhibition. Held in Lucca, Italy’s beating heart of paper production, MIAC gathers over 250 international exhibitors and showcases the latest technologies, machinery, and equipment about Tissue paper.
At Stand #A1, Bolzoni Group will showcase a range of handling solutions designed to support the diverse demands of the paper industry, from tissue production to broader applications across the sector:
  • AURAMO AR-RT Tissue Paper Roll Clamp
  • SILVER LINE LC-G Bale Clamp
  • BOLZONI 1-Rot 360-degree Rotating Lift Table
Visit Bolzoni at MIAC and its a range of solutions specifically developed for the tissue paper sector.
Expertise that moves the tissue industry forward: AR-RT paper roll clamp
At the heart of Bolzoni Group’s offering for the tissue sector is the AR-RT tissue paper roll clamp, a solution specifically engineered to meet the delicate demands of tissue roll handling. Designed for large-diameter, low-density rolls, the AR-RT combines lightweight construction with high clamping precision, ensuring safe and efficient operations even in high-volume environments.
The clamp features slim, rounded arms for safer handling in confined spaces and includes built-in pad protection loops to prevent wear and tear that could damage the roll surface.
“The AR-RT clamp is engineered to meet the unique demands of tissue roll handling,” says Teemu Jauhiainen, Bolzoni Group Forest Product Manager. “With capacities ranging from 1.500 to 6.000 kg (3,300 to 13,200 Lbs) and roll diameters up to 2,700 mm (106"), it’s designed to handle even the softest and most loosely wound rolls. Its fast and accurate 180-degree rotation system improves handling efficiency and reduces the risk of roll end damage.’’
Its optimized arm geometry enhances visibility and maneuverability, while the hydraulic control system allows for smooth, responsive clamping.
Precision starts at the contact point: contact pads designed for tissue paper
A key feature of the AR-RT clamp lies in its dedicated contact pads, developed specifically for the tissue paper industry. These pads are engineered to provide maximum grip while applying minimal surface pressure, protecting the integrity of even the most delicate rolls.
Available in a variety of shapes, and coatings, the pads are tailored to suit different paper grades and operational needs. Their modular design allows for easy replacement and customization, ensuring long-term performance and adaptability.
In high-volume operations, the right pad surface can mean the difference between flawless handling and costly damage.
Robust solutions for paper bale logistics: the Silver Line LC-G bale clamp
Another highlight at MIAC 2025 is the LC-G Silver Line Bale Clamp.
Engineered for intensive use in paper mills, recycling plants, and logistics centers, the LC-G model is particularly valued in the paper sector for its robust design and ability to handle bales of recycled paper and pulp safely and efficiently.
This paper bale clamp features robust, well-protected components designed to withstand wear and tear in demanding environments. It is ideal for minimizing costs without compromising performance. High tensile aluminum profiles, reversible and interchangeable with wear-resistant plastic inserts, ensure long life and low lifetime costs.
The Silver Line forklift truck attachment range is dedicated to operators seeking extremely robust equipment, enduring tough applications.
Versatility in material handling: Bolzoni lift table model 1E-Rot
At MIAC 2025, we will also present the BOLZONI lift tables, showcasing significant benefits for the paper processing industry. Lifting tables are essential tools in this sector, facilitating the handling, ensuring smooth transitions between different stages of production. To include a lift table into the production line enhances efficiency and minimizes the risk of injury, creating a safer workplace for operators.
Find at Stand #A1 the Bolzoni lifting table 1E-Rot, a versatile addition to any production or logistics environment.
Compact and robust, this lift table brings real value wherever ergonomic positioning, lifting, or rotating of loads is required, making it a valuable asset in packaging, converting, and warehouse applications.
With a 450 kg (1,000 Lbs) capacity, a 1.250 x 800 mm (49" x 31") platform, and a 360° manual circular turn table with integrated locking system, the 1E-Rot lifting table model enables precise load handling, improves operator safety and comfort, and helps reduce cycle times. Its user-friendly design and reliable performance make it an excellent choice for companies seeking to optimize workflow and enhance workplace ergonomics, whether in the tissue industry or beyond.
Versatile and compact, the Lifting Table 1E-Rot performs 360-degree rotation of the load in both directions.
Come and meet our Sales Engineers at MIAC, Stand #A1, Lucca, Italy, 8-10 October 2025, and find out how our forest product handling products can support your business.
For more information on Paper Product Handling, or to organize a demo unit at your facilities, get in touch with us. Visit our web site, or contact the nearest BOLZONI, AURAMO and MEYER representative.
Bolzoni, Auramo and Meyer are Bolzoni Group brands.
The Bolzoni Group is a market leader in the production of forklift truck attachments, forks and lift tables. The company has manufacturing plants in Italy, Germany, Finland, America and China and through its network of direct branches and independent dealers covering all continents it is able to satisfy all market requirements.
Bolzoni SpA (Group HQ)
+39 052... Show
Via I Maggio, 103
I-29027 Casoni di Podenzano,
PC, Italy
Muncie, IN, United States
