Attachment for delicate loads: stabau presents new paper roll clamp
- 8 May 2025 ( #1229 )
Rotating, gripping, protecting – stabau GmbH is expanding its portfolio with a new, low-maintenance generation of paper roll clamps.
The attachment has a 180° rotary drive, optimized arm geometry, rounded contact plates and end position damping for vertical storage of the rolls. All hydraulic systems are easily accessible so that maintenance and repairs can be carried out quickly.
Paper roll clamps enable the gentle handling of both horizontal and vertical paper rolls. The central element and particular advantage of the new clamps from stabau is the 180° rotary drive, which ensures that vertical rolls are stored in a completely straight position. Together with the optimized gripper arm geometry, the rotary drive enables precise adjustment to different roll sizes and positions. This makes it possible to use the clamp across industries, for example in paper and packaging production, in printing companies or for loading HGVs or ships.
Since the contact plates are in direct contact with the delicate goods, it is essential that they can handle the paper rolls safely and gently. In order to adapt the contact pressure to the load requirements and prevent the rolls from slipping, stabau provides the clamps as standard with an adjustable pressure relief valve and rounded cast contact plates with a structured surface. In addition, the end position damping maintains precision and care when storing paper rolls in a vertical position. Different coatings, load capacities and configuration options are also available for custom requirements, for example a split long arm for gripping two rolls in parallel.
The clamps have a pressure relief valve and rounded cast contact plates with a structured surface so that they can handle the paper rolls safely and gently.
Well-designed hydraulics, maximum safety
The paper roller clamps from stabau are not only flexible, but are also designed to be particularly easy to maintain. All hydraulic components are easily accessible, which simplifies maintenance and repairs and minimizes downtime. All cylinders also have check valves to ensure the operational reliability of the hydraulic systems. "Our new paper roller clamps combine stability, user-friendliness and safety with maximum adaptability. The flexible configurations in all load capacity classes allow our customers to apply the clamps in a variety of different ways, while at the same time providing maximum protection for materials, employees and vehicles", summarizes Stefan Pinter, Export Sales Manager.
The precise adaptation to different roll sizes and positions as well as the customised configuration options make it suitable for use in a wide range of industries.
For further information, visit https://www.https://www.stabau.com/en-gb.
About Stabau
Since its foundation in 1974, stabau GmbH has stood for the highest quality and innovation in the development, manufacture and sale of attachments, stationary systems and telescopic forks for intralogistics under the product name stabau. With its headquarters and sole production facility in Meschede, North Rhine-Westphalia, stabau has established itself as one of the world's leading suppliers and the first point of contact for special designs in the forklift industry. The extensive product portfolio serves forklift attachments with load capacities of up to 80 tons and is used in various industries, including wood, metal, building materials, beverages, recycling and logistics. With a team of around 200 dedicated specialists, stabau is committed to the quality promise “Made in Germany”, characterized by continuous innovation, quality assurance according to DIN standards and customer-oriented solutions.
Get in touch with HUBTEX Maschinenbau GmbH & Co. KG
+49-66... Show
Industriepark West
Werner-von-Siemens-Straße 8
36041 Fulda,
Germany
